tcPDU issue with SW 1.22-tcPDU
After Setup Set Time of return and Event device not Start
Steps to reproduce
Set Factory Reset with button
Login to default IP
Set DHCP
Set Time of return to 60 and Set the output after starting to Enabled <<Pic1>>
Setup Email settings
Test Email Ok
Add Event <<Pic2>>
Test Event power off (out1name)
Get Email notifications and the output return to ON
Restart Device from <Firmware And Backup  ->>Restart>
Or Cut the Power from device and reconnect
The device not Start any more you must Use the Reset Button
And if use factory reset the <<Set the output after starting >> is not Enabled
and not all output ports go ON
The Restore from backup Function  and the Import Data Function
Oweride the MAC address to the Device
Thanks
tcPDU issue with SW 1.22-tcPDU - przez Vchris - 07-10-2024, 03:50 PM
RE: tcPDU issue with SW 1.22-tcPDU - przez tonymony - 08-26-2024, 04:17 PM
