tcPDU issue with SW 1.22-tcPDU - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: tcPDU (https://forum.tinycontrol.pl/forumdisplay.php?fid=37) +--- Dział: tcPDU (https://forum.tinycontrol.pl/forumdisplay.php?fid=38) +--- Wątek: tcPDU issue with SW 1.22-tcPDU (/showthread.php?tid=2987) |
tcPDU issue with SW 1.22-tcPDU - Vchris - 07-10-2024 After Setup Set Time of return and Event device not Start Steps to reproduce Set Factory Reset with button Login to default IP Set DHCP Set Time of return to 60 and Set the output after starting to Enabled <<Pic1>> Setup Email settings Test Email Ok Add Event <<Pic2>> Test Event power off (out1name) Get Email notifications and the output return to ON Restart Device from <Firmware And Backup ->>Restart> Or Cut the Power from device and reconnect The device not Start any more you must Use the Reset Button And if use factory reset the <<Set the output after starting >> is not Enabled and not all output ports go ON The Restore from backup Function and the Import Data Function Oweride the MAC address to the Device Thanks RE: tcPDU issue with SW 1.22-tcPDU - tonymony - 08-26-2024 (07-10-2024, 03:50 PM)Vchris napisał(a): After Setup Set Time of return and Event device not Start Hi, we know this issue and are working on a solution. To mitigate it you can increase outStartOnTime (Set the output after starting) to a value, high enough that LK will get the address from the DHCP server, eg. 15 [s]. This way, we are delaying sending emails, which is problematic here. However, this workaround works only for power resets. In contrast, a software reset will still make the device inaccessible (as long as the output used in Events was on before the software reset). |
