Auth enabled
#21
wilkxt post_id=13972 time=1510352656 user_id=61 napisał(a):
danpin post_id=13968 time=1510321813 user_id=6381 napisał(a):Hello,
Where did you download the fw 1.43b version, on the LAN v3 page just find Firmware V1.40b - 02.08.2017?
Thank you!
On this forum
http://www.tinycontrol.pl/forum/viewtopi...=60#p13238
Ok, thank you!
Hi, since the implementation of OLED display, could the authors of firmware be kind and make a wiki or an article that brings some light in settings regarding OLED dispaly and how to show different info's on it. Big Grin
something like those showed here:
http://tinycontrol.pl/en/oled-rtc-i2c-expansion-2/
octavvian post_id=13975 time=1510385299 user_id=6211 napisał(a):Right....
speaking of it, eta on a the next firmware? Wink
It depend when i get this board to the test
OK, regarding things that can be displayed on OLED implemented recently, see previous post.
Thanks!
PS Regarding arduino compatible AC measure module the code attached is the one that is accurate.
octavvian post_id=13989 time=1510523044 user_id=6211 napisał(a):Hi, since the implementation of OLED display, could the authors of firmware be kind and make a wiki or an article that brings some light in settings regarding OLED dispaly and how to show different info's on it. Big Grin
http://tinycontrol.pl/forum/viewtopic.ph...=50#p12587
From google translator
OLED displays are divided into 4 lines, their contents can be configured with a-z characters, A-Z, 0-9, and they can be inserted from the sensors in the same way as the HTTP URL, the percent sign, the two-digit sensor number, and the divider. for example.
% 062 - inserts input voltage 06 divided by 100 (2) to display the decimal value
% 611- inserts uptime 61, depending on the third digit in minutes (1), in seconds (0) and in hours (2)
The initialization of the display is made at the LK3 startup and at the time of activation on the OLED, so it must be connected before the LK start or at a later connection, then to enable its operation (as it was already turned on, it must be turned off and turned on).
sensors number page 28 http://tinycontrol.pl/wp-content/uploads...008_EN.pdf
additional(not specified in the manual) sensors number:
PM2.5- 57
PM10 - 58
P1- 59
CO2- 60
uptime -61
IP- 62
octavvian post_id=14010 time=1510691573 user_id=6211 napisał(a):PS Regarding arduino compatible AC measure module the code attached is the one that is accurate.
Is this archive corect? I have no files after extract
7z archive, I attached in zip format also
Regarding OLED display, I'm not native in polish so the search in forum was limited Big Grin.
Thanks for explaining.
Any luck so far with testing arduino AC voltage measure module?
octavvian post_id=14146 time=1511260986 user_id=6211 napisał(a):Any luck so far with testing arduino AC voltage measure module?
I did not recive yet this module
