DS18B20 wiring for RJ12 / max cable lenght of AM2320
Hello,
I have several question regarding sensors and sensor connections.
  1. I would like to connect some DS18B20 to my LanController v3.6 via RJ12 splitter.
    What is the sequence for RJ12?
  2. A question for RJ12 splitter:
    - is it possible to connect more than one AM2320 to LanController via RJ12 splitter?
  3. At the moment i am using one AM2320 but i always need to press "I2C sensor detection" (Inputs menu) for displaying the values, after a few mins or sometime a few hours it does not show automatically any more. Is it possible that the sensor is too far from the LanController? The cable lenght is around 8-10m.
  4. There is a menu called "I2C and 1Wire Sensors". Is there any manual how to use this section?
Thank you!
(05-25-2020, 10:56 AM)atosz napisał(a): [*]I would like to connect some DS18B20 to my LanController v3.6 via RJ12 splitter.
https://tinycontrol.pl/wp-content/upload...0_mm-1.pdf
(05-25-2020, 10:56 AM)atosz napisał(a): [*]A question for RJ12 splitter:
Now, only one
(05-25-2020, 10:56 AM)atosz napisał(a): [*]At the moment i am using one AM2320 but i always need to press "I2C sensor detection" (Inputs menu) for displaying the values, after a few mins or sometime a few hours it does not show automatically any more. Is it possible that the sensor is too far from the LanController? The cable lenght is around 8-10m.
[*]There is a menu called "I2C and 1Wire Sensors". Is there any manual how to use this section?
[/list]
https://tinycontrol-software.gitlab.io/l...e-sensors/
