LK2 SW:3.18 - scheduler and Events Config
Vitam.
Mam kontroler LK2 HW: 2.0 SW: 3.18.
I muszę ustawić przekaźnik OUT0, aby włączał się na podstawie temperatury czujnika INP6, gdy temperatura jest niższa niż 19 ° C o 16:00 - 22:00, a temperatura jest niższa niż 21 ° C o 22:00 - 16:00.
Czy ogólnie można zaprogramować to w LK2 FW: 3.18?
dziękuję
Hello.
I have LK2 HW controller: 2.0 SW: 3.18.
And I need to set the OUT0 relay to switch on based on the temperature of the INP6 sensor when the temperature is below 19 ° C at 16:00 - 22:00 and the temperature is below 21 ° C at 22:00 - 16:00.
Is it generally possible to program this into LK2 FW: 3.18?
Well thank you
(02-16-2020, 04:15 PM)psedlacko napisał(a): Vitam.
dziękuję
Hello.
ell thank you
In LK3.5/7 it simple but in LK2 you must use additional out to do this.
In scheduler set out1 active from 22-16 and inactive from 16-22.
In events sets out0 when temp is below 19. out0 connect by out1
I have one mor question. For using 21° C I must use two next outputs and connect it together? Rigrt?
PeterS
(02-24-2020, 01:02 PM)psedlacko napisał(a): I have one mor question. For using 21° C I must use two next outputs and connect it together? Rigrt?
PeterS
yes, connected in series
