LK2 SW:3.18 - scheduler and Events Config - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: LK2 SW:3.18 - scheduler and Events Config (/showthread.php?tid=1025) |
LK2 SW:3.18 - scheduler and Events Config - psedlacko - 02-16-2020 Vitam. Mam kontroler LK2 HW: 2.0 SW: 3.18. I muszę ustawić przekaźnik OUT0, aby włączał się na podstawie temperatury czujnika INP6, gdy temperatura jest niższa niż 19 ° C o 16:00 - 22:00, a temperatura jest niższa niż 21 ° C o 22:00 - 16:00. Czy ogólnie można zaprogramować to w LK2 FW: 3.18? dziękuję ------------- Hello. I have LK2 HW controller: 2.0 SW: 3.18. And I need to set the OUT0 relay to switch on based on the temperature of the INP6 sensor when the temperature is below 19 ° C at 16:00 - 22:00 and the temperature is below 21 ° C at 22:00 - 16:00. Is it generally possible to program this into LK2 FW: 3.18? Well thank you RE: LK2 SW:3.18 - scheduler and Events Config - wilkxt - 02-20-2020 (02-16-2020, 04:15 PM)psedlacko napisał(a): Vitam. In LK3.5/7 it simple but in LK2 you must use additional out to do this. In scheduler set out1 active from 22-16 and inactive from 16-22. In events sets out0 when temp is below 19. out0 connect by out1 RE: LK2 SW:3.18 - scheduler and Events Config - psedlacko - 02-24-2020 I have one mor question. For using 21° C I must use two next outputs and connect it together? Rigrt? PeterS RE: LK2 SW:3.18 - scheduler and Events Config - wilkxt - 02-24-2020 (02-24-2020, 01:02 PM)psedlacko napisał(a): I have one mor question. For using 21° C I must use two next outputs and connect it together? Rigrt?yes, connected in series |
