7 godzin(y) temu
Hi,
I'm dealing with the problem accessing web interface on Tinycontrol PDU units.
Web browser displays text "Failed to read existing file"
Curl returns "500 Internal Server Error":
I have already tried various firmware versions (1.30, 1.37, 1.38), none of them helped.
Factory reset (both API eeprom_reset and front panel reset button) didn't help.
Power-cycled units, no change at all.
3 out of 9 units have this issue, I made no recent config changes.
API and SNMP work fine.
Has anybody had similar issue?
Thanks in advance.
$ curl -v "http://_HOSTNAME_/"
* Host _HOSTNAME_:80 was resolved.
* IPv6: (none)
* IPv4: IP.AD.DR.ESS
* Trying IP.AD.DR.ESS:80...
* Established connection to _HOSTNAME_ (IP.AD.DR.ESS port 80) from MY.AD.DR.ESS port 42130
* using HTTP/1.x
> GET / HTTP/1.1
> Host: _HOSTNAME_
> User-Agent: curl/8.17.0
> Accept: */*
* Request completely sent off
< HTTP/1.1 500 Internal Server Error
< Content-Type: text/html
< Content-Length: 28
* Connection #0 to host _HOSTNAME_:80 left intact
Failed to read existing fileI have already tried various firmware versions (1.30, 1.37, 1.38), none of them helped.
Thanks in advance.
