Tinycontrol PDU - web interface does not work - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: tcPDU (https://forum.tinycontrol.pl/forumdisplay.php?fid=37) +--- Dział: tcPDU (https://forum.tinycontrol.pl/forumdisplay.php?fid=38) +--- Wątek: Tinycontrol PDU - web interface does not work (/showthread.php?tid=3235) |
Tinycontrol PDU - web interface does not work - robo - 11-28-2026 Hi, I'm dealing with the problem accessing web interface on Tinycontrol PDU units. Web browser displays text "Failed to read existing file" Curl returns "500 Internal Server Error": Kod: $ curl -v "http://_HOSTNAME_/"I have already tried various firmware versions (1.30, 1.37, 1.38), none of them helped. Factory reset (both API eeprom_reset and front panel reset button) didn't help. Power-cycled units, no change at all. 3 out of 9 units have this issue, I made no recent config changes. API and SNMP work fine. Has anybody had similar issue? Thanks in advance. |
