11-15-2017, 01:01 PM
octavvian post_id=13989 time=1510523044 user_id=6211 napisał(a):Hi, since the implementation of OLED display, could the authors of firmware be kind and make a wiki or an article that brings some light in settings regarding OLED dispaly and how to show different info's on it.http://tinycontrol.pl/forum/viewtopic.ph...=50#p12587![]()
something like those showed here:
http://tinycontrol.pl/en/oled-rtc-i2c-expansion-2/
From google translator
OLED displays are divided into 4 lines, their contents can be configured with a-z characters, A-Z, 0-9, and they can be inserted from the sensors in the same way as the HTTP URL, the percent sign, the two-digit sensor number, and the divider. for example.
% 062 - inserts input voltage 06 divided by 100 (2) to display the decimal value
% 611- inserts uptime 61, depending on the third digit in minutes (1), in seconds (0) and in hours (2)
The initialization of the display is made at the LK3 startup and at the time of activation on the OLED, so it must be connected before the LK start or at a later connection, then to enable its operation (as it was already turned on, it must be turned off and turned on).
sensors number page 28 http://tinycontrol.pl/wp-content/uploads...008_EN.pdf
additional(not specified in the manual) sensors number:
PM2.5- 57
PM10 - 58
P1- 59
CO2- 60
uptime -61
IP- 62
