Differential temp and antifreeze system
Hi.
I have two temp sensors. I configure without problem the differential part and everything works ok. When the difference is above 4 degrees Celsius the Relay is changing state (pump is on), else the relay is open (pump is off).
I want to configure also the 7 input (temperature sensor) for antifreeze. When the Temperature is 1 Degree Celsius the Relay must change state (pump on), else the relay is off (pump off).
Can I do that and how? Please help.
Christos
