11-02-2017, 02:41 PM
Thanks a lot.
Auth enabled
Thanks a lot.
11-08-2017, 03:24 PM
Hi, could this sensor be connected to LK3 to mesure AC voltage?
http://klinikrobot.com/product/electrica...odule.html In what way? Thanks
11-09-2017, 04:10 PM
11-10-2017, 03:09 AM
I have that one... not what you suggested.
Thanks anyway.
11-10-2017, 04:32 PM
octavvian post_id=13952 time=1510143868 user_id=6211 napisał(a):Hi, could this sensor be connected to LK3 to mesure AC voltage? This its be ok, but measure value will be not 230AC but couple VDC. You must count this value to true value. What do you want to use it for?
11-10-2017, 04:50 PM
Hello,
Where did you download the fw 1.43b version, on the LAN v3 page just find Firmware V1.40b - 02.08.2017? Thank you!
11-11-2017, 12:04 AM
Hi, I tough it was proper for measure the AC line voltage. The sensor is designed for arduino AC line voltage measurement and is pretty accurate so i come to you maybe there is a way on hooking and calibrating so it's usable in LK3.
Thanks!
11-11-2017, 01:20 AM
octavvian post_id=13970 time=1510347846 user_id=6211 napisał(a):Hi, I tough it was proper for measure the AC line voltage. The sensor is designed for arduino AC line voltage measurement and is pretty accurate so i come to you maybe there is a way on hooking and calibrating so it's usable in LK3. I will test this and add to lk3 soft
11-11-2017, 01:24 AM
danpin post_id=13968 time=1510321813 user_id=6381 napisał(a):Hello, On this forum http://www.tinycontrol.pl/forum/viewtopi...=60#p13238
11-11-2017, 10:28 AM
Right....
speaking of it, eta on a the next firmware?
