8 relay out
#31
1.light green
2. serial i think is 3440
if only light green its means that LKis in bootlader mode, load upgrade file again by tftp (standard console program form windows or linux).
in windows tftp –i 192.168.1.100 put „upgrade file.bin”.
ok, i try to make an update but the LK no response.
.jpg   LK.jpg (Rozmiar: 117.6 KB / Pobrań: 3,436)
what was you last IP in LK? Use last IP
ok, i use the last ip 192.168.0.100 but the same result in the last post Sad(
LED green (in RJ45) is blinking?
yes blinking.
1.You use cross cabel?
2.Do scan port 69, maby IP LK was changed, when scan you find proper IP.
I use a normal cable and router, ok i try to scan port 69. Thx
i try but ... nothing. Sad
