07-21-2013, 01:33 PM
Can release a firmware for 8 relay outputs, 1 relay LK onboard + 7 relay on extension board ?
Thx,
acasa2013
Thx,
acasa2013
8 relay out
Thx, acasa2013
07-22-2013, 03:27 PM
This is not a problem, I will build one myself, I just needed assigned to IDC 10 pins for out. I have done several projects and I really need 8 relay outputs, please help me in this issue, solve this problem if I have to buy more LK.
THX
07-22-2013, 03:50 PM
You need only button on Panel Control page to switch ON/OFF outs?
07-22-2013, 08:42 PM
Yes, and have the same options an functionality as the other five outputs (possibility to work with inputs and scheduler for definite time).
Thx for the prompt response.
07-23-2013, 08:47 AM
To all function is to low free memory in microcontroler. What functions or inputs you not use?
07-23-2013, 11:45 AM
can not assign pins 1 and 2 analog imput and PWM, out1, out2, out3 and out4 from IDC10 ? are exactly seven outputs on idc10 + 1 relay out from LK = 8 out ?
THX
07-23-2013, 12:47 PM
yes I use pin 1 and 2 and PWM on IDC10 but it is no hardware problem, but software. I must cut some other software, what functions you not use in LK?
tomek |
