04-26-2019, 07:09 PM
Hi .
It would be possible after start of LK3 do not to activate the outputs PWM in LK3 ...?????
George.
George.
Activate The Outputs PWM in LK3
Hi .
It would be possible after start of LK3 do not to activate the outputs PWM in LK3 ...????? George.
04-27-2019, 12:02 AM
What do you mean by not activating?
After start PWM outs are not active.
04-27-2019, 12:53 PM
wilkxt post_id=16016 time=1556312555 user_id=61 napisał(a):What do you mean by not activating? Unfortunately to me at every start is active . I am using Version: 1.51b1 in LK3 and https://www.ledats.pl/en/kontrolazasilan...results=79 I may have some wrong regulation .. ![]() I have something wrong ? :?: George.
05-04-2019, 05:15 PM
Please any help ???
and any help for Reset time in PWM ???? George.
05-06-2019, 11:55 PM
First questins is how you use PMW out, as normal OUT (on/off) or as PWM out?
You have sets PWM as normal outs.
05-07-2019, 06:58 PM
wilkxt post_id=16020 time=1557176133 user_id=61 napisał(a):First questins is how you use PMW out, as normal OUT (on/off) or as PWM out? Hi thanks for the ansering . I use PMW as normal OUT (on/off) . Cytat:You have sets PWM as normal outsI do not understand that . I have put a little more over a photo with my set-up ... for the PMW I have not made any other arrangements . George.
05-15-2019, 01:52 PM
wilkxt post_id=16028 time=1557768828 user_id=61 napisał(a):when you start LK3, you want to PWM out low or high? Sorry to be late to answer . I want to PWM out low . |
