INTERVAL TIMER FUNCTION REQUEST IN SHEDUL TIME DEPEND ON DI
hello
is possible to have firmware with option in shedul time switch relay 0-4 to time depend on state INP1D,INP2D?
example:
every day between 14:00-20:00 if INP1D=1 every 20 minutes set OUT1 to 1 for 2 sec
thanks for reply
with best regard Peter
We can quickly add options OUT 0-4 switching at fixed time intervals when INP1D is active but not at specific times, it is more complicated. Is it required it to be at certain times?
Do you use a watchdog?
we don´t use wotchdog, and currently we can use request function only after working time whitch is varian .
sweet napisał(a):hello
example:
thanks for reply
We add this functionality, upfrade soft to 2.29 (http://tinycontrol.ats.pl/forum/viewtopic.php?f=2&t=510) version and test
For your example you must set:
.jpg   auto panel.jpg (Rozmiar: 127.5 KB / Pobrań: 5,353)
.jpg   auto sched.jpg (Rozmiar: 78.09 KB / Pobrań: 5,358)
hello, we have problem with this firmware,
1) after reset controller out1 switch on and stay in this position
2) controller send two impulz, second impulz is random
i attach settings off shedull
.jpg   lan.jpg (Rozmiar: 142.62 KB / Pobrań: 4,813)
thanks for reply
sweet napisał(a):hello, we have problem with this firmware,
thanks for reply
1.What you set in "Auto Switch Out" on Control Panel?
2.Do you use some Input from "Config events"?
hello
I test Auto switch Out checked and unchecked and this option nothing doing with auto on rele to permanent switch to 1 after reset.
I use event INP1D to send mail id board switch REL.
use this soft http://tinycontrol.ats.pl/forum/viewtopi...f=2&t=2567
