Do not save the settings
Hi, i have problem with memory LK3...sw -1.40b, hw - 6x DS18, 1x AM2320, and connect 2x input
(I have been following this problem since sw1.38)
After losing power, lk3 forgets the previous setting (input negation, events and scheduler), but the old setting still remembers (sw-1.37 and older) (the image, the position of the input values on the image, the description of the input and the output, the part of the scheduler)
Please, where can the problem be?
thx kollnjak
How you connected DS and AM2320? take spliter picture
rozdelovac - 6-6 wire spliter
A) jsou pripojeny SCL,+5V, SDA, GND
B) jsou pripojeny +3,3V, GND, 1wire
C) 6wire pripojeny do LK3
.jpg   spliter.jpg (Rozmiar: 1.39 MB / Pobrań: 2,182)
When you disconect 6wire from LK3, settings are remember?
Do you do reset do default after upgrade?
After the AM2320 is disconnected, LK3 OK will run.
I am badly connected AM2320 ?? Or what is wrong?
