Liczba postów: 4
Liczba wątków: 1
Hi to all,
I'm using lan board and considering to use for my irrigation project, so I need to attach relay board, my question is can I use relay board to control 12V solenoid valves!? Or any other device powered with 12V dc (LED light strip), board is powered with 12V dc.
Thanks
Liczba postów: 2,358
you need to add an additional transistor
Liczba postów: 4
Liczba wątków: 1
Hi, can you provide more details on this, which transistor, where, is there maybe some sort documentation!?. Can you suggest setup for irrigation project, simple time scheduled open close valve.
Thanks
Liczba postów: 4
Liczba wątków: 1
Ah, now I can see. Ok, maybe to clarify my question, if I buy relayboard (RelayBoardv3), from tinycontrol company, what kind of devices I can control!? Can I use relay to switch devices (ON/OFF) which are powered with 12V DC, 24V or 220 (30)V AC!? Can someone give more info on this topic, maybe example of use with relayboard, tutorial, you have mentioned earlier under Help section of webpage "Watering by Lan Controler" can you give quick info on this practical use,
Again, great product and thanks in advance.
Liczba postów: 4
Liczba wątków: 1
Hi, thanks for response, I will go with relay board.
