01-29-2026, 12:13 PM
Hello,
when I turn on sending to MQTT server, CPU go to 100% usage. Where is problem?
MQTT and CPU on 100%
Hello,
07-21-2026, 04:25 PM
Check if your loop isn't publishing messages too fast without any delay or sleep, which often maxes out the CPU. Also, make sure you're using asynchronous publishing or a proper keep-alive setting so the MQTT client doesn't block the main thread
