Anyone using data transfer from Li-ion BMS to LK3 via Modbus?
I have a problem with displaying the negative value of the current, it displays the positive value of the current correctly.
09-09-2024, 07:20 PM (Ten post był ostatnio modyfikowany: 09-09-2024, 07:22 PM przez stAch.)
(08-18-2024, 06:22 PM)dusanstr napisał(a): Anyone using data transfer from Li-ion BMS to LK3 via Modbus?
09-09-2024, 07:53 PM (Ten post był ostatnio modyfikowany: 09-09-2024, 08:26 PM przez dusanstr.)
Thanks, I have these setting options in Modbus settings.
I have tried all of them setting and nothing works properly to display a negative current value.
Solar panels: 3960 Wp, Solar Controller: EPEVER-150VDC/80A, Inverters: Household / Victron 5000 VA/24V, Water heating / Victron 3000 VA/24V, Li-ion battery: 18650 56P/8S + Li-ion 50Ah 3P/8S + Li -ion 150Ah 8S = 31.6V/440Ah (LK3, LK3.6, LK3.8)
ok, hlásím za vás chybu při čtení záporné hodnoty na Modbusu ...
