tcPDU Firmware
hallo
how can I download the latest firmware for tcPDU now I have SW 1.05-strip | HW 1.0 and it doesn't work like expected
at the https://tinycontrol.pl/tcpdu/firmware/ I get 404 Page not found
You have to wait a few days
1.07 firmware, unzip before upload
.zip   lk4-listwa_firmware_1_07-strip.zip (Rozmiar: 948.26 KB / Pobrań: 403)
Wink
Thanks for the update but it did not solve the issues that i had
I noticed that in the new firmware it is not enabled (Set the output after starting) as Default
When I enable <Time of return> and turn OFF the output from <Status>, <<Status for User> or<Outputs>
Does not revert to ON remains Off (Time of return not Work)
If I go back and turn it ON it will go back to OFF (Time of return  Work)
If I change fast ON OFF It does not return to ON (Time of return not Work)
Also when I cut and restore power to the PDU
the outputs Will become ON because  I have enabled <Set the output after starting>
but then it turns OFF because of the <Time of return>
I also haven't found a way to reset all the output with one command (Off -ON)
ok, we fix this i next firmware
