sdm72 with tinycontrol gsm
Hi,
I am trying to use Tinycontrol GSM 4.2     HW=1.0, SW=1.27
Using this modbus connected to SDM72
https://aws1.discourse-cdn.com/arduino/o...7953a.jpeg
I used Serial port (tried swap)
Serial RX ---- to DI
Serial TX ---- to RO
Serial 3.3V ---- to VIN
Serial GND ---- to GND
and SDM72 A to A, B to B.
usartsensor=4
mqttselect from 35 to 44
it seems OK, even on SDM72 I can see "phone" icon that it communicates, but I always get 0 values
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se1', ... (5 bytes))
device1/se1 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se2', ... (5 bytes))
device1/se2 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se3', ... (5 bytes))
device1/se3 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se4', ... (5 bytes))
device1/se4 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se5', ... (5 bytes))
device1/se5 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se6', ... (5 bytes))
device1/se6 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se7', ... (5 bytes))
device1/se7 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se8', ... (5 bytes))
device1/se8 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se9', ... (5 bytes))
device1/se9 0.000
Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se10', ... (5 bytes))
device1/se10 0.000
when I try modbusread I get
modbusread=0 0
I just need current power, not sure what exactly those 10 values are, but I hoped one of them is current power on all phases.
I also have made test and with USB-modbus converter I was able to read data from SDM72 with Python
Any help appreciated.
Thank you.
This converter will not work, it need additional pin for control transmission direction.
We use other converter like here:
https://tinycontrol.pl/pl/accessories/bo...odbus-rtu/
I will check GSM with SMD72 with latest firmware and let you know.
(11-25-2022, 04:06 PM)notek napisał(a): This converter will not work, it need additional pin for control transmission direction.
thank you, I will buy that module, but please let me know about wiring. As I understand tinycontrol GSM doesn't have such port as LAN controler
