 sdm72 with tinycontrol gsm - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: Kontrolery GSM (https://forum.tinycontrol.pl/forumdisplay.php?fid=29) +--- Dział: GSM kontroler GSM (https://forum.tinycontrol.pl/forumdisplay.php?fid=5) +--- Wątek: sdm72 with tinycontrol gsm (/showthread.php?tid=2583)  |
sdm72 with tinycontrol gsm - Peter Xing - 11-20-2022 Hi, I am trying to use Tinycontrol GSM 4.2 HW=1.0, SW=1.27 Using this modbus connected to SDM72 https://aws1.discourse-cdn.com/arduino/original/4X/8/0/f/80f64678793fad208b7a4f3a169aa6345937953a.jpeg I used Serial port (tried swap) Serial RX ---- to DI Serial TX ---- to RO Serial 3.3V ---- to VIN Serial GND ---- to GND and SDM72 A to A, B to B. Kod: usartsensor=4it seems OK, even on SDM72 I can see "phone" icon that it communicates, but I always get 0 values Kod: Client (null) received PUBLISH (d0, q0, r0, m0, 'device1/se1', ... (5 bytes))when I try modbusread I get Kod: modbusread=0 0I just need current power, not sure what exactly those 10 values are, but I hoped one of them is current power on all phases. I also have made test and with USB-modbus converter I was able to read data from SDM72 with Python Any help appreciated. Thank you. RE: sdm72 with tinycontrol gsm - notek - 11-25-2022 This converter will not work, it need additional pin for control transmission direction. We use other converter like here: https://tinycontrol.pl/pl/accessories/boards/modbus-rtu/ I will check GSM with SMD72 with latest firmware and let you know. RE: sdm72 with tinycontrol gsm - Peter Xing - 11-29-2022 (11-25-2022, 04:06 PM)notek napisał(a): This converter will not work, it need additional pin for control transmission direction. thank you, I will buy that module, but please let me know about wiring. As I understand tinycontrol GSM doesn't have such port as LAN controler RE: sdm72 with tinycontrol gsm - Peter Xing - 12-11-2022 (11-25-2022, 04:06 PM)notek napisał(a): This converter will not work, it need additional pin for control transmission direction. hi, please any update ? I have not module for LAN but no idea how to connect it Thanks,  |
