LanKontroler v 3.5 unacessible
Hi, in case of firmware upgrade issue my device doesnt response on any IP. What i can do (steps) to restore firmware. I tried to hold reset device by reset button (and use bootloader switch) and use default IP to connect but with out any response. - no ping on default IP. Any idea, please? Or could someone write steps how to correctly resart device to default IP (but FW is out now probably).
Thank you
David
when you reset to default IP is get from DHCP serwer, look for your router for IP
use LKTool by search ip device
