LanKontroler v 3.5 unacessible - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3.5 (https://forum.tinycontrol.pl/forumdisplay.php?fid=28) +--- Wątek: LanKontroler v 3.5 unacessible (/showthread.php?tid=2209) |
LanKontroler v 3.5 unacessible - david_grela - 12-01-2021 Hi, in case of firmware upgrade issue my device doesnt response on any IP. What i can do (steps) to restore firmware. I tried to hold reset device by reset button (and use bootloader switch) and use default IP to connect but with out any response. - no ping on default IP. Any idea, please? Or could someone write steps how to correctly resart device to default IP (but FW is out now probably). Thank you David RE: LanKontroler v 3.5 unacessible - wilkxt - 12-01-2021 when you reset to default IP is get from DHCP serwer, look for your router for IP use LKTool by search ip device |
