Can not upgrade to 2.10
Hi,
I am trying to upgrade LanController to the last version of the firmware.
I followed the instruction on the manual.Switched off the module. Plugin the power connector. and then press enter:
d:\LanController>tftp -i -v 192.168.0.89 PUT "lan_module_ver_2_10.bin"
WinAgents TFTP Client version 2.0b Copyright © 2004-2011 by Tandem Systems, Ltd.
http://www.winagents.com - Software for network administrators
Transfering file lan_module_ver_2_10.bin to server in octet mode...
Transferring data from 192.168.0.89...
Packet will be sent. len=68, opcode=2
Error occurred during the file transfer (Error code = 0):
Timeout expired. Retries expired.
d:\LanController>
I tried also with Lan Controller Tools.
Same result.
I can see with wireshark the TFTP packet sent from my PC to the Lan Controller module but there is no response.
Any advice ?
Regards
Emkant
This upgrade procedure works correctly:
Open a prompt command and digit:
tftp -i -v ipaddressLanController PUT lan_module_ver_XXX.bin
before pressing Enter press the reset button on LANKontroller and hold the button down
after some seconds the tftp transfer start (the -v flag allow you to see the details of the transfer).
Release the reset button.
After about 90seconds the transfer will be completed.
Regards
Emkant
Hi
Simple you can use LAN ControlerTools application ftp://ftp.wirelesslan.pl/LAN%20controlle...s_v1.2.exe
Regards
