Can not upgrade to 2.10 - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: Can not upgrade to 2.10 (/showthread.php?tid=22) |
Can not upgrade to 2.10 - emkant - 03-08-2012 Hi, I am trying to upgrade LanController to the last version of the firmware. I followed the instruction on the manual.Switched off the module. Plugin the power connector. and then press enter: d:\LanController>tftp -i -v 192.168.0.89 PUT "lan_module_ver_2_10.bin" WinAgents TFTP Client version 2.0b Copyright © 2004-2011 by Tandem Systems, Ltd. http://www.winagents.com - Software for network administrators Transfering file lan_module_ver_2_10.bin to server in octet mode... Transferring data from 192.168.0.89... Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Packet will be sent. len=68, opcode=2 Error occurred during the file transfer (Error code = 0): Timeout expired. Retries expired. d:\LanController> I tried also with Lan Controller Tools. Same result. I can see with wireshark the TFTP packet sent from my PC to the Lan Controller module but there is no response. Any advice ? Regards Emkant Re: Can not upgrade to 2.10 - emkant - 03-08-2012 This upgrade procedure works correctly: Open a prompt command and digit: tftp -i -v ipaddressLanController PUT lan_module_ver_XXX.bin before pressing Enter press the reset button on LANKontroller and hold the button down after some seconds the tftp transfer start (the -v flag allow you to see the details of the transfer). Release the reset button. After about 90seconds the transfer will be completed. Regards Emkant Re: Can not upgrade to 2.10 - wilkxt - 03-12-2012 Hi Simple you can use LAN ControlerTools application ftp://ftp.wirelesslan.pl/LAN%20controller/LAN%20Controler%20Tools_v1.2.exe Regards tomek |
