POE does not work
Hello All,
I have 2 LanController (3.5-3.6), boughted a few amonth ago. Then i tried them via standard 12V adapter and worked. I was really happy to solve what i needed (0-10 V creating via PWM).
Now i wanted to intall TCs and i really surprised that not powering on via POE. I tried the other one, and the same.
I am using a Zyxel 8 port POE switch and there is a professional AP that also Works with PoE, and it Works fine (55V)
What do i need to do to powering them via PoE?
Thanks, atosz
Hi,
LK has a power passive not activ.
You must have a switch with PoE passiv.
(02-16-2020, 09:15 AM)marcinb napisał(a): Hi,
Hello Marcin,
Thank you for your helping!
Hello Marcin,
LK3.8 will probably have POE active
