POE does not work - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V3.5 (https://forum.tinycontrol.pl/forumdisplay.php?fid=28) +--- Wątek: POE does not work (/showthread.php?tid=1024) |
POE does not work - atosz - 02-16-2020 Hello All, I have 2 LanController (3.5-3.6), boughted a few amonth ago. Then i tried them via standard 12V adapter and worked. I was really happy to solve what i needed (0-10 V creating via PWM). Now i wanted to intall TCs and i really surprised that not powering on via POE. I tried the other one, and the same. I am using a Zyxel 8 port POE switch and there is a professional AP that also Works with PoE, and it Works fine (55V) What do i need to do to powering them via PoE? Thanks, atosz RE: POE does not work - marcinb - 02-16-2020 Hi, LK has a power passive not activ. You must have a switch with PoE passiv. RE: POE does not work - atosz - 02-17-2020 (02-16-2020, 09:15 AM)marcinb napisał(a): Hi,Hello Marcin, Thank you for your helping! RE: POE does not work - wilkxt - 02-17-2020 (02-17-2020, 10:23 AM)atosz napisał(a):(02-16-2020, 09:15 AM)marcinb napisał(a): Hi,Hello Marcin, LK3.8 will probably have POE active |
