Activate The Outputs PWM in LK3
Hi .
It would be possible after start of LK3 do not to activate the outputs PWM in LK3 ...?????
George.
What do you mean by not activating?
After start PWM outs are not active.
wilkxt post_id=16016 time=1556312555 user_id=61 napisał(a):What do you mean by not activating?
Unfortunately to me at every start is active .
I am using Version: 1.51b1 in LK3 and https://www.ledats.pl/en/kontrolazasilan...results=79
I may have some wrong regulation ..
[Obrazek: LANKON-088.jpg]
I have something wrong ? :?:
George.
Please any help ???
and any help for Reset time in PWM ????
George.
First questins is how you use PMW out, as normal OUT (on/off) or as PWM out?
You have sets PWM as normal outs.
wilkxt post_id=16020 time=1557176133 user_id=61 napisał(a):First questins is how you use PMW out, as normal OUT (on/off) or as PWM out?
Hi thanks for the ansering .
I use PMW as normal OUT (on/off) .
Cytat:You have sets PWM as normal outs
I do not understand that .
I have put a little more over a photo with my set-up ...
for the PMW I have not made any other arrangements .
George.
For you state active is low or high?
when you start LK3, you want to PWM out low or high?
wilkxt post_id=16028 time=1557768828 user_id=61 napisał(a):when you start LK3, you want to PWM out low or high?
Sorry to be late to answer .
I want to PWM out low .
