DHT22 senzor , wrong humidity
Hello!
I use LH v. 3.13 and senzor DHT 22 for temperature and humidity.
Temperature shows OK, but humidity is usually always 99.9%, The lowest value is 88%.
Senzor is outside.
Now is value 88%, correct is 55-60%
what is wrong?
regards
Check or change sensor.
I had the same problem with DHT22 outside.
Regards.
What is life yours sensors (DHT22 or DHT11). My first sensor DHT11 was destroyed after 3 or 4 months. Second DHT22 after 5 months. Third after 4 months. What is yours experience with this sensors?
But all the time the sensors was working correctly.
