Remote Control Server ---> Client Control
Can you help in solving it?
192.168.1.100 remote kontrol ---> enable server
192.168.1.101 remote kontrol ---> enable client --- INP1D ---> OUT0
192.168.1.101 = INP1D ----> LOW => 192.168.1.100 OUT0 =ON
192.168.1.101 = INP1D ----> HIGH => 192.168.1.100 OUT0 =OFF
OK NO PROBLEM
192.168.1.101 INP1D ----> LOW |POWER OFF |
INP1D ----> HIGH ----> |POWER ON | 192.168.1.100 OUT0 =OFF
OK NO PROBLEM
192.168.1.100 |POWER OFF |
|POWER ON | 192.168.1.100 OUT0 =OFF (192.168.1.101 => INP1D ----> LOW)
PROBLEM
tou use LK 1.2 HW or new module LK2? We solve problem in next soft upgrade
new module LK2 I can use, not a problem
Thank You
To work settings, how should we do?
which version works?
(hardware,software)
we don't have new soft
urgently needed for a client
using a dry control system
and is having problems
If possible, could you solve?
ok, 2-3 days
The new version has been published
Did this error is resolved?
If resolved, what settings should we do?
Thank you for your interest
I jus write path, the problem is when serwer is power off and next you power on serwer and serwer don't check INPD state in client?
192.168.1.100 |POWER OFF or POWER RESET|
