8 relay out
Can release a firmware for 8 relay outputs, 1 relay LK onboard + 7 relay on extension board ?
Thx,
acasa2013
firmware is not all, you must have board with 7 relays
This is not a problem, I will build one myself, I just needed assigned to IDC 10 pins for out. I have done several projects and I really need 8 relay outputs, please help me in this issue, solve this problem if I have to buy more LK.
THX
You need only button on Panel Control page to switch ON/OFF outs?
Yes, and have the same options an functionality as the other five outputs (possibility to work with inputs and scheduler for definite time).
Thx for the prompt response.
To all function is to low free memory in microcontroler. What functions or inputs you not use?
can not assign pins 1 and 2 analog imput and PWM, out1, out2, out3 and out4 from IDC10 ? are exactly seven outputs on idc10 + 1 relay out from LK = 8 out ?
THX
yes I use pin 1 and 2 and PWM on IDC10 but it is no hardware problem, but software. I must cut some other software, what functions you not use in LK?
not use Watchdog
Waht soft version you use 2.xx or 3.xx?
