07-09-2024, 03:37 PM (Ten post był ostatnio modyfikowany: 07-22-2024, 01:52 PM przez dusanstr.)
Well thank you
Solar panels: 3960 Wp, Solar Controller: EPEVER-150VDC/80A, Inverters: Household / Victron 5000 VA/24V, Water heating / Victron 3000 VA/24V, Li-ion battery: 18650 56P/8S + Li-ion 50Ah 3P/8S + Li -ion 150Ah 8S = 31.6V/440Ah (LK3, LK3.6, LK3.8)
Well thank you
Well thank you
Thanks for the answer.
Have a nice day.
Via LK3, I load data from the BMS Li-ion battery via Modbus in the user settings. Everything works perfectly, I just have a problem with the display of the negative current when discharging the battery, it displays the positive value correctly. paper io
Well thank you
Make sure the Modbus register for current is correctly interpreted as a signed value (e.g., 16-bit signed integer) to properly display negative current during battery discharge.
To correctly display negative current during battery discharge, verify that the Modbus register for current is correctly translated as a signed number (e.g. a 16-bit signed integer). escape road
Check if your LK3 is reading the current as unsigned; changing it to signed (INT16) should display negative values correctly. Some BMS systems also use a separate register to indicate charge or discharge mode. If so, you may need to manually adjust the sign based on that register. Baldi’s Basics Plus
Well thank you
Thank you
