07-09-2024, 03:37 PM (Ten post był ostatnio modyfikowany: 07-22-2024, 01:52 PM przez dusanstr.)
Well thank you
Solar panels: 3960 Wp, Solar Controller: EPEVER-150VDC/80A, Inverters: Household / Victron 5000 VA/24V, Water heating / Victron 3000 VA/24V, Li-ion battery: 18650 56P/8S + Li-ion 50Ah 3P/8S + Li -ion 150Ah 8S = 31.6V/440Ah (LK3, LK3.6, LK3.8)
Well thank you
Well thank you
Thanks for the answer.
Have a nice day.
Well thank you
Thank you
09-13-2025, 05:28 AM (Ten post był ostatnio modyfikowany: 09-13-2025, 05:28 AM przez 205theost.)
Interesting issue! To tackle the negative current display in your BMS Modbus setup via LK3, double-check your register mapping. Ensure you're interpreting the value as a signed integer. Some systems might require bitwise operations to handle the sign properly. Perhaps playing Snow rider while troubleshooting for a mental break might help you see new insights.
