BMS Li-ion battery via Modbus
Well thank you
Well thank you
Well thank you
Well thank you
Thanks for the answer.
Have a nice day.
Well thank you
Thank you
Interesting issue! To tackle the negative current display in your BMS Modbus setup via LK3, double-check your register mapping. Ensure you're interpreting the value as a signed integer. Some systems might require bitwise operations to handle the sign properly. Perhaps playing Snow rider while troubleshooting for a mental break might help you see new insights.
