Data transfer from BMS li-ion battery to LK3 over Modbus
Anyone using data transfer from Li-ion BMS to LK3 via Modbus?
I have a problem with displaying the negative value of the current, it displays the positive value of the current correctly.
I also asked here: https://forum.tinycontrol.pl/showthread.php?tid=2986 , but no one answered me.
Solar panels: 3960 Wp, Solar Controller: EPEVER-150VDC/80A, Inverters: Household / Victron 5000 VA/24V, Water heating / Victron 3000 VA/24V, Li-ion battery: 18650 56P/8S + Li-ion 50Ah 3P/8S + Li -ion 150Ah 8S = 31.6V/440Ah (LK3, LK3.6, LK3.8)
(08-18-2024, 06:22 PM)dusanstr napisał(a): Anyone using data transfer from Li-ion BMS to LK3 via Modbus?
show setting this this modbus? mark this negative value...
https://wiki.li-bat.com/comm/modbus/register-map/
Thanks, I have these setting options in Modbus settings.
I have tried all of them setting and nothing works properly to display a negative current value.
ok, hlásím za vás chybu při čtení záporné hodnoty na Modbusu ...
Is there any hope that the new SW version will solve the problem of reading negative values via Modbus?
Thank you
Bude nejaká nádej, že sa podarí v novej verzii SW vyriešiť problém pri zápornom čítaní hodnôt cez Modbus?
Ďakujem
