BMS Li-ion battery via Modbus
Well thank you
Well thank you
Well thank you
Well thank you
Thanks for the answer.
Have a nice day.
Check if your LK3 is reading the current as unsigned; changing it to signed (INT16) should display negative values correctly. Some BMS systems also use a separate register to indicate charge or discharge mode. If so, you may need to manually adjust the sign based on that register.  Baldi’s Basics Plus
Well thank you
Thank you
