Hello, I have a problem with the home assistant because when I add a sensor that measures my temperature via INPA, there is only the option V or mV, but that is wrong because there are no other options, the same is the case with current sensors where the consumption is 3 amperes but it shows volts
08-22-2024, 10:05 PM (Ten post był ostatnio modyfikowany: 08-22-2024, 10:10 PM przez dusanstr.)
Hello, I had a similar problem and I solved it by creating a new sensor in HA in configuration.yaml.
Adjust the name of the sensor and the measured quantity according to your needs.
