Home Assistatn Inpa problems - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler V4 (https://forum.tinycontrol.pl/forumdisplay.php?fid=36) +--- Wątek: Home Assistatn Inpa problems (/showthread.php?tid=3000) |
Home Assistatn Inpa problems - syky95 - 08-21-2024 Hello, I have a problem with the home assistant because when I add a sensor that measures my temperature via INPA, there is only the option V or mV, but that is wrong because there are no other options, the same is the case with current sensors where the consumption is 3 amperes but it shows volts RE: Home Assistatn Inpa problems - dusanstr - 08-22-2024 Hello, I had a similar problem and I solved it by creating a new sensor in HA in configuration.yaml. Adjust the name of the sensor and the measured quantity according to your needs. Kod: - sensor: |
