03-29-2022, 01:58 PM
(Ten post był ostatnio modyfikowany: 03-29-2022, 02:31 PM przez FaneBranesti.)
(03-29-2022, 10:19 AM)wilkxt napisał(a):(03-29-2022, 09:40 AM)FaneBranesti napisał(a): [quote pid="9248" dateline="1648529430"]
P.S. When I am at home (connected on LAN) and it does not work, I can use your specific application able to find it and reboot. Apropos, is there a way do do that from external IP?
From the external address yes, but you need to be redirected on the home router to the LK address and the appropriate port.
Try to connect LK direct to PC without switch and watch if the http connection will also drop.
Do you have any sensor connected to LK?
[/quote]
I inserted by mistake "not" in "at home (connected on LAN) and it does not work". I wanted to say IT WORKS...
Now, how to connect from external IP? I can connect to the LAN Controler (from outside), the necessary port is forwarded for its specific internal IP. But when I tried to use the external IP: Port (in fact a DDNS name: Port), I receive the error: "Unable to receive the reset message. Check network connectivity..." I tried the string which I used for connection (and it works when controller responds - 1, 2 days). Can you suggest what kind of string to use? I will try to persuade my wife to send me the external IP from my home. It is not a fix IP, that's why the need of DDNS solution...
Edited: I have just tried external IP separated by port through ":" but the same error message. You can try 82.79.21.120:8088. Does it work to reboot the controller?
I am using 'LAN Controler Tools ver.1.2'
