Weird LK3 issue
(09-30-2021, 07:54 PM)wilkxt napisał(a): Bme280 od on i2c intarface. Do you set this sensor in i2c settings as primary sensor.
Do you have spliter to ds18b20 nad i2c?
Primary sensor
It won't detect BME and it won't read serial number of DS18, so it's not just i2c, it's also 1-wire.
Yes I have copied the settings off of a working device to be sure. Like I said, I have like 10 controllers, they all work with the same settings, 4 of which in the same network. Also, it worked when rebooted and set to BME280. So the setting is correct and working until IP/hostname is changed.
Splitter
I have this sensor here that comes with the splitter, but I also tried with a DS18B20 I had, that doesn't have one. I admit most of my tests were made with the BME, but after BME stopped working I tried with a directly inserted DS18. So I am fairly certain that it won't work with 1-wire but not 100%. I'll try again.
Weird LK3 issue - przez IMNdi - 09-30-2021, 07:15 PM
RE: Weird LK3 issue - przez wilkxt - 09-30-2021, 07:54 PM
RE: Weird LK3 issue - przez IMNdi - 10-01-2021, 12:00 PM
RE: Weird LK3 issue - przez wilkxt - 10-01-2021, 12:51 PM
RE: Weird LK3 issue - przez IMNdi - 10-12-2021, 11:05 PM
