(01-18-2021, 03:25 PM)kollnjak napisał(a):
(01-18-2021, 01:58 PM)tonymony napisał(a):
(01-16-2021, 02:45 PM)kollnjak napisał(a):
(01-12-2021, 01:44 PM)wilkxt napisał(a):
(12-27-2020, 04:30 PM)kollnjak napisał(a): Hi,
I would like to ask you for the possibility of manual ON / OFF of virtual outputs. And display them after the user logs in.
What do you want to use it for?
hello, there are many cases .. I have more Lk3,6, one of them works as a control for heating - where the mode is outside the home .. it would be nice so that this mode can be turned on / off at user login (out0-5 are occupied )
To make it clear - would you like to have some flags (ON/OFF) that can be set and view on LK page?
If that's the case then we might expose 8 fields for this purpose - these fields are already in use in scheduler and events tab and are called there event1-8.
yes, if event1-8 could be displayed and ON / OFF on the user page, it would be enough for me
Unfortunately, even in version 1.36, I did not find where I can turn on the virtual outputs as a user Sad Will this ever be incorporated into another version?
Użytkownicy przeglądający ten wątek: 26 gości
