01-21-2015, 12:39 AM
hello
I am also new to this - i found in manual :
"If you haave the proper checks the condition of a number of sensors is to force the state OUTX outputs and setting the PWM generator to be that was las registered event" so i think there is no way to use and/or
Alterntative solution when you have all outputs in use is is a "trick" to use pwm outputs as relay outputs.
