01-21-2015, 12:29 AM
Thank you for your answer!
I have only one Output and this is the default Out0. I dont have the additional Outputs (1-4) from the IDC10-1 and I thing that there is no need for them. One pump to control so one output with two states ON -OFF.
The case is:
If INP6 < 60 AND DIFF > 8 then Out0=ON else Out0=OFF
The key is in the AND....
This way there is no need for priority in the configuration.
But how to configure it?
In the configuration there is no explanation about priority (if there are any) or about upper (only) or down limit (only).
I tried all the combination but every time I restart the controller the Out0 is always on if I have something in the Inp6 and it is enabled.
There is no way to have logical AND - OR and set the order of execution of each check.
I dont understand if I have to configure only one sensor or multiple.
I am new to this hardware and try to figure out how this works.
Kind regards
Christos
The case is:
Kind regards
Christos
