01-20-2015, 08:58 PM
Hi.
Can you tell me how to define only an upper limit for a temperature sensor?
I have Inp6 and I want to switch OFF Out0 if the temp is 60 degrees or higher.
The Out0 switches ON from the DIFF and only if the DIFF is 8 or more degrees.
The OUT0 (relay) goes ON if the DIFF is 8 degrees and more.
I want to switch OFF the relay OUT0 if the Inp6 is higher than 60 degrees.
Please help....someone.
Thank you.
Thank you.
