11-04-2014, 02:21 PM
misho napisał(a):What is the chance to make static mapping for DS18B20?
Inp6 = sensor ID=64-Bit Serial Code
Inp7= sensor ID=64-Bit Serial Code
Because if i connect 4 x DS18B20 (All will be OK). What will happen when i disconnect one sensor?
If needed can be build in in firmware...? And when you need to change sensor just upload customized firmware.
Yes, we add static mapping for DS18, about 1 month
misho napisał(a):What resolution is set for reading DS18B20?
default 12-bit
misho napisał(a):How many often is refresh reading from 1-wire bus? every 1s?yes,1 s
