1-Wire DS18B20 sensor mapping - Wersja do druku +- Forum tinycontrol (https://forum.tinycontrol.pl) +-- Dział: LanKontroler - sprzęt i wersje wsadów, problemy, zastosowanie (https://forum.tinycontrol.pl/forumdisplay.php?fid=3) +--- Dział: LanKontroler - wersje oprogramowania (https://forum.tinycontrol.pl/forumdisplay.php?fid=4) +--- Wątek: 1-Wire DS18B20 sensor mapping (/showthread.php?tid=497) |
1-Wire DS18B20 sensor mapping - misho - 10-30-2014 Hi, What is the chance to make static mapping for DS18B20? Inp6 = sensor ID=64-Bit Serial Code Inp7= sensor ID=64-Bit Serial Code ..... Because if i connect 4 x DS18B20 (All will be OK). What will happen when i disconnect one sensor? If needed can be build in in firmware...? And when you need to change sensor just upload customized firmware. What resolution is set for reading DS18B20? How many often is refresh reading from 1-wire bus? every 1s? Thanks in advance! Re: 1-Wire DS18B20 sensor mapping - wilkxt - 11-04-2014 misho napisał(a):What is the chance to make static mapping for DS18B20? Yes, we add static mapping for DS18, about 1 month misho napisał(a):What resolution is set for reading DS18B20? default 12-bit misho napisał(a):How many often is refresh reading from 1-wire bus? every 1s?yes,1 s Re: 1-Wire DS18B20 sensor mapping - misho - 11-04-2014 Hi, Thanks for answer! ![]() I will wait for the new firmware ![]() Re: 1-Wire DS18B20 sensor mapping - misho - 01-08-2015 Happy New Year ![]() Any new updates? Re: 1-Wire DS18B20 sensor mapping - wilkxt - 01-12-2015 Hi no yet |
