Event Config
Hi, hope you can help.
I have been trying to figure out how the event rules work but it has all ended in fail.
I would like to use the LK to turn off a relay (OUT0) if the voltage of INP3 is more than 14.5v but also if its less than 11.5v.
I have this working to turn off at 11.5v but when voltage returns above 11.5v it does not set the relay back, how can I get this to work please?
Also I would like to use an additional (add on board) relay (OUT1) to turn a fan on above 40c (temp) but then turn off once temp is below 40c.
