BMS Li-ion battery via Modbus
(07-09-2024, 03:37 PM)dusanstr napisał(a): Hello, I want to ask you for help.
Via LK3, I load data from the BMS Li-ion battery via Modbus in the user settings. Everything works perfectly, I just have a problem with the display of the negative current when discharging the battery, it displays the positive value correctly.
Well thank you
I can confirm that negative reading via MODBUS is now working in the new SW 1.65 version.
Thank you
Solar panels: 3960 Wp, Solar Controller: EPEVER-150VDC/80A, Inverters: Household / Victron 5000 VA/24V, Water heating / Victron 3000 VA/24V, Li-ion battery: 18650 56P/8S + Li-ion 50Ah 3P/8S + Li -ion 150Ah 8S = 31.6V/440Ah (LK3, LK3.6, LK3.8)
BMS Li-ion battery via Modbus - przez dusanstr - 07-09-2024, 03:37 PM
RE: BMS Li-ion battery via Modbus - przez dusanstr - 07-22-2024, 01:52 PM
RE: BMS Li-ion battery via Modbus - przez stAch - 09-10-2024, 10:40 AM
RE: BMS Li-ion battery via Modbus - przez dusanstr - 08-09-2025, 05:26 PM
RE: BMS Li-ion battery via Modbus - przez 205theost - 09-13-2025, 05:28 AM
RE: BMS Li-ion battery via Modbus - przez Hollyranklin - 04-20-2026, 06:23 AM
