BMS Li-ion battery via Modbus
(07-09-2024, 03:37 PM)dusanstr napisał(a): Hello, I want to ask you for help.
Via LK3, I load data from the BMS Li-ion battery via Modbus in the user settings. Everything works perfectly, I just have a problem with the display of the negative current when discharging the battery, it displays the positive value correctly.
Well thank you
Check if the current value from the BMS is a signed integer and configure the LK3 to interpret it as such. Verify Modbus register settings and scaling factors in LK3. Use a Modbus diagnostic tool to confirm raw data, and update firmware if needed. Contact LK3 support if the issue persists.
BMS Li-ion battery via Modbus - przez dusanstr - 07-09-2024, 03:37 PM
RE: BMS Li-ion battery via Modbus - przez dusanstr - 07-22-2024, 01:52 PM
RE: BMS Li-ion battery via Modbus - przez stAch - 09-10-2024, 10:40 AM
RE: BMS Li-ion battery via Modbus - przez totalcoot - 01-02-2025, 10:57 AM
RE: BMS Li-ion battery via Modbus - przez dusanstr - 01-09-2025, 06:31 PM
